Ana içeriğe geç
HP Chromebook 11A G8 EE Touchpad Replacement
Neye ihtiyacın var
  1. HP Chromebook 11A G8 EE Touchpad Replacement, Keyboard Assembly: adım 1, 2 resimden 1. HP Chromebook 11A G8 EE Touchpad Replacement, Keyboard Assembly: adım 1, 2 resimden 2.
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Touchpad Replacement: adım 2, 3 resimden 1. HP Chromebook 11A G8 EE Touchpad Replacement: adım 2, 3 resimden 2. HP Chromebook 11A G8 EE Touchpad Replacement: adım 2, 3 resimden 3.
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Touchpad Replacement: adım 3, 2 resimden 1. HP Chromebook 11A G8 EE Touchpad Replacement: adım 3, 2 resimden 2.
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
  4. HP Chromebook 11A G8 EE Touchpad Replacement, Touchpad: adım 4, 2 resimden 1. HP Chromebook 11A G8 EE Touchpad Replacement, Touchpad: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, carefully disconnect the touchpad board ribbon cable from the touchpad board.
    • Using tweezers, carefully peel back the clear sheet that covers the the touchpad board screws.
  5. HP Chromebook 11A G8 EE Touchpad Replacement: adım 5, 2 resimden 1. HP Chromebook 11A G8 EE Touchpad Replacement: adım 5, 2 resimden 2.
    • Use the Phillips #0 screwdriver and remove the top three 1.6 mm screws from the touchpad.
    • Remove the four bottom 2 mm screws using the same Phillips #0 screwdriver.
  6. HP Chromebook 11A G8 EE Touchpad Replacement: adım 6, 1 resimden 1.
    • Lift the touchpad brackets off of the alignment pins on the top cover and remove.
  7. HP Chromebook 11A G8 EE Touchpad Replacement: adım 7, 1 resimden 1.
    • Using tweezers, carefully lift the touchpad board off of the board to remove.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ella Portwood
684 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 22
Her zaman: 421
