Ana içeriğe geç
HP Chromebook 11A G8 EE Wi-Fi Card Replacement
Neye ihtiyacın var
  1. HP Chromebook 11A G8 EE Wi-Fi Card Replacement, Keyboard Assembly: adım 1, 2 resimden 1. HP Chromebook 11A G8 EE Wi-Fi Card Replacement, Keyboard Assembly: adım 1, 2 resimden 2.
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: adım 2, 3 resimden 1. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: adım 2, 3 resimden 2. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: adım 2, 3 resimden 3.
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: adım 3, 2 resimden 1. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: adım 3, 2 resimden 2.
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
  4. HP Chromebook 11A G8 EE Wi-Fi Card Replacement, Wi-Fi Card: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using your tweezers, unplug the battery connector from the motherboard.
  5. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: adım 5, 3 resimden 1. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: adım 5, 3 resimden 2. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: adım 5, 3 resimden 3.
    • Using your tweezers, peel back the clear sheet covering the Wi-Fi card.
    • Using a Phillips #0 screwdriver, remove the screw securing the Wi-Fi card cover.
    • Using your tweezers, remove the cover.
  6. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: adım 6, 2 resimden 1. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: adım 6, 2 resimden 2.
    • Using your tweezers, unsnap the the coaxial antenna cables from the Wi-Fi Card.
    • Slide the Wi-Fi card out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jackson Dembski
127 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 37
Her zaman: 691
