Giriş
If you notice that your computer's battery life has significantly decreased or if your computer shut downs unexpectedly, it could be due to a failing battery. Use this guide to remove and replace your battery.
Neye ihtiyacın var
Position your closed computer on a flat surface, with the back facing up.
Remove all eight 8 mm Philips #0 screws from the bottom cover.
Identify the second cable and the ZIF connector attatching the cable to the motherboard. Then, unclip it with the iFixit opening tool.
To do this, use the iFixit opening tool to flip up the small locking flap located on the ZIF connector.
Proceed by gently pulling the cable straight out of the connector to disconnect the cable.
