Giriş
Whether the sound quality of your laptop's speakers is distorted or your laptop has suffered physical damage, it is best to replace them. In fact, a damaged speaker may not function properly, causing issues with sound output such as low volume, or crackling noises. In some cases, the speaker may not work at all, resulting in no sound output. To replace the speakers on your computer, follow this guide.
Neye ihtiyacın var
Position your closed computer on a flat surface, with the back facing up.
Identify eight 8 mm Philips #1 screws on the back of your computer.
After identifying all the screws, remove them with the Philips #0 Screwdriver.
Identify the second cable and the ZIF connector attatching the cable to the motherboard. Then, unclip it with the iFixit opening tool.
To do this, use the iFixit opening tool to flip up the small locking flap located on the ZIF connector.
Proceed by gently pulling the cable straight out of the connector to disconnect the cable.
