Ana içeriğe geç
HP Chromebook 14 G5 Motherboard Replacement
Neye ihtiyacın var
  1. HP Chromebook 14 G5 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Remove nine 2.5mm screws embedded in the back cover using the Phillips #0 screwdriver.
  2. HP Chromebook 14 G5 Motherboard Replacement: adım 2, 1 resimden 1.
    • Open the back cover using a spudger.
  3. HP Chromebook 14 G5 Motherboard Replacement: adım 3, 2 resimden 1. HP Chromebook 14 G5 Motherboard Replacement: adım 3, 2 resimden 2.
    • Then you can see the motherboard marked in the yellow rectangle.
    • Unscrew the 4.1mm screws around the motherboard using the Phillips #00 screwdriver.
  4. HP Chromebook 14 G5 Motherboard Replacement: adım 4, 2 resimden 1. HP Chromebook 14 G5 Motherboard Replacement: adım 4, 2 resimden 2.
    • Disconnect the two Flexible Flat Cable (FFC) from the device.
  5. HP Chromebook 14 G5 Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the motherboard from the device.
Sonuç
We omitted some photos of reassembling the device. For this part, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 1,163
