Ana içeriğe geç
HP Chromebook 14 G5 SD card reader Replacement
Neye ihtiyacın var
  1. HP Chromebook 14 G5 SD card reader Replacement, SD card reader: adım 1, 1 resimden 1.
    • Remove nine 2.5mm screws embedded in the back cover using the Phillips #0 screwdriver.
  2. HP Chromebook 14 G5 SD card reader Replacement: adım 2, 1 resimden 1.
    • Open the back cover using a spudger.
  3. HP Chromebook 14 G5 SD card reader Replacement: adım 3, 1 resimden 1.
    • Now we can see the SD card reader (in the yellow rectangle) that we need to tear down.
  4. HP Chromebook 14 G5 SD card reader Replacement: adım 4, 1 resimden 1.
    • Remove the three 2mm screws around the SD card reader using the Phillips #00 Screwdriver.
  5. HP Chromebook 14 G5 SD card reader Replacement: adım 5, 2 resimden 1. HP Chromebook 14 G5 SD card reader Replacement: adım 5, 2 resimden 2.
    • Disconnect the Flexible Flat Cable (FFC) from the motherboard.
  6. HP Chromebook 14 G5 SD card reader Replacement: adım 6, 1 resimden 1.
    • Remove the SD card reader the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 289
