Ana içeriğe geç
HP Chromebook 14-Q010DX Battery Replacement
Neye ihtiyacın var
    1. HP Chromebook 14-Q010DX Battery Replacement, Keyboard and Touchpad: adım 1, 2 resimden 1. HP Chromebook 14-Q010DX Battery Replacement, Keyboard and Touchpad: adım 1, 2 resimden 2.
      • Flip the laptop so the base of the laptop is facing you.
      • Using the #00 screwdriver, unscrew the 13 screws.
      FixBot'a Sor
      Yorum Ekle
    2. HP Chromebook 14-Q010DX Battery Replacement: adım 2, 3 resimden 1. HP Chromebook 14-Q010DX Battery Replacement: adım 2, 3 resimden 2. HP Chromebook 14-Q010DX Battery Replacement: adım 2, 3 resimden 3.
      • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
      • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
      FixBot'a Sor
      Yorum Ekle
    3. HP Chromebook 14-Q010DX Battery Replacement: adım 3, 3 resimden 1. HP Chromebook 14-Q010DX Battery Replacement: adım 3, 3 resimden 2. HP Chromebook 14-Q010DX Battery Replacement: adım 3, 3 resimden 3.
      • Warning! Handle the flaps and ribbon cables with care to prevent damage.
      • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
      • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
      • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
      FixBot'a Sor
      Yorum Ekle
    4. HP Chromebook 14-Q010DX Battery Replacement: adım 4, 1 resimden 1.
      • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
      • The tape has no function other than to keep the wire tucked away.
      FixBot'a Sor
      Yorum Ekle
    5. HP Chromebook 14-Q010DX Battery Replacement: adım 5, 1 resimden 1.
      • Set aside the detached keyboard.
      FixBot'a Sor
      Yorum Ekle
    1. HP Chromebook 14-Q010DX Battery Replacement, Speaker: adım 6, 3 resimden 1. HP Chromebook 14-Q010DX Battery Replacement, Speaker: adım 6, 3 resimden 2. HP Chromebook 14-Q010DX Battery Replacement, Speaker: adım 6, 3 resimden 3.
      • Undo the black tape located on the bottom from the frame of the laptop.
      • Using fingers or the spudger, slide out the black connector indicated on the left.
      • Use a #00 screwdriver to remove the two screws.
      FixBot'a Sor
      Yorum Ekle
    2. HP Chromebook 14-Q010DX Battery Replacement: adım 7, 2 resimden 1. HP Chromebook 14-Q010DX Battery Replacement: adım 7, 2 resimden 2.
      • Gently remove the speakers.
      FixBot'a Sor
      Yorum Ekle
    1. HP Chromebook 14-Q010DX Battery Replacement, Battery: adım 8, 2 resimden 1. HP Chromebook 14-Q010DX Battery Replacement, Battery: adım 8, 2 resimden 2.
      • Note the shape that this wire strip is resting at and that the blue tip of the strip goes into the right connector for reassembly.
      • Lift the black flaps and gently pull the strip out.
      • Set the strip aside.
      FixBot'a Sor
      Yorum Ekle
    2. HP Chromebook 14-Q010DX Battery Replacement: adım 9, 3 resimden 1. HP Chromebook 14-Q010DX Battery Replacement: adım 9, 3 resimden 2. HP Chromebook 14-Q010DX Battery Replacement: adım 9, 3 resimden 3.
      • Remove the screw.
      • Use your fingers to pull the white tab out of the black slot above the battery.
      FixBot'a Sor
      Yorum Ekle
    3. HP Chromebook 14-Q010DX Battery Replacement: adım 10, 1 resimden 1.
      • Gently remove battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Kevin Piper
1.602 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-2, Watkins Winter 2015 USF Tampa, Team 17-2, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S17G2
4 Üyeler
96 adet Kılavuz yazıldı
3Kılavuz Yorumları
Nice guide, guys!
dergrossmeister50 - Yanıt Paylaş
Thanks, hope it made life a bit easier for you!
Kevin Piper - Yanıt Paylaş
Very clear and concise. Nice going! Thank you.
sparkydog1725 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 43
Her zaman: 14,359
