Ana içeriğe geç
HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement
Neye ihtiyacın var
  1. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement, Keyboard and Touchpad: adım 1, 2 resimden 1. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement, Keyboard and Touchpad: adım 1, 2 resimden 2.
    • Flip the laptop with the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew these screws.
  2. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: adım 2, 3 resimden 1. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: adım 2, 3 resimden 2. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: adım 2, 3 resimden 3.
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
  3. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: adım 3, 3 resimden 1. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: adım 3, 3 resimden 2. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: adım 3, 3 resimden 3.
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
  4. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: adım 4, 1 resimden 1.
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
  5. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: adım 5, 1 resimden 1.
    • Set aside the detached keyboard.
  6. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement, Bluetooth and Wireless Card: adım 6, 2 resimden 1. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement, Bluetooth and Wireless Card: adım 6, 2 resimden 2.
    • Using a spudger, remove the white and black cables from the card.
  7. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: adım 7, 2 resimden 1. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: adım 7, 2 resimden 2.
    • Remove screw from card.
  8. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: adım 8, 1 resimden 1.
    • Gently pull card at a 45° angle to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin Piper
1.587 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-2, Watkins Winter 2015 USF Tampa, Team 17-2, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S17G2
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 7
Her zaman: 1,680
