Ana içeriğe geç
HP Chromebook 14-Q010DX Hard drive Replacement
Neye ihtiyacın var
  1. HP Chromebook 14-Q010DX Hard drive Replacement, Keyboard and Touchpad: adım 1, 2 resimden 1. HP Chromebook 14-Q010DX Hard drive Replacement, Keyboard and Touchpad: adım 1, 2 resimden 2.
    • Flip the laptop so the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew the 13 screws.
    FixBot'a Sor
    Yorum Ekle
  2. HP Chromebook 14-Q010DX Hard drive Replacement: adım 2, 3 resimden 1. HP Chromebook 14-Q010DX Hard drive Replacement: adım 2, 3 resimden 2. HP Chromebook 14-Q010DX Hard drive Replacement: adım 2, 3 resimden 3.
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. HP Chromebook 14-Q010DX Hard drive Replacement: adım 3, 3 resimden 1. HP Chromebook 14-Q010DX Hard drive Replacement: adım 3, 3 resimden 2. HP Chromebook 14-Q010DX Hard drive Replacement: adım 3, 3 resimden 3.
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
    FixBot'a Sor
    Yorum Ekle
  4. HP Chromebook 14-Q010DX Hard drive Replacement: adım 4, 1 resimden 1.
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
    FixBot'a Sor
    Yorum Ekle
  5. HP Chromebook 14-Q010DX Hard drive Replacement: adım 5, 1 resimden 1.
    • Set aside the detached keyboard.
    FixBot'a Sor
    Yorum Ekle
  6. HP Chromebook 14-Q010DX Hard drive Replacement, Speaker: adım 6, 3 resimden 1. HP Chromebook 14-Q010DX Hard drive Replacement, Speaker: adım 6, 3 resimden 2. HP Chromebook 14-Q010DX Hard drive Replacement, Speaker: adım 6, 3 resimden 3.
    • Undo the black tape located on the bottom from the frame of the laptop.
    • Using fingers or the spudger, slide out the black connector indicated on the left.
    • Use a #00 screwdriver to remove the two screws.
    FixBot'a Sor
    Yorum Ekle
  7. HP Chromebook 14-Q010DX Hard drive Replacement: adım 7, 2 resimden 1. HP Chromebook 14-Q010DX Hard drive Replacement: adım 7, 2 resimden 2.
    • Gently remove the speakers.
    FixBot'a Sor
    Yorum Ekle
  8. HP Chromebook 14-Q010DX Hard drive Replacement, Battery: adım 8, 2 resimden 1. HP Chromebook 14-Q010DX Hard drive Replacement, Battery: adım 8, 2 resimden 2.
    • Note the shape that this wire strip is resting at and that the blue tip of the strip goes into the right connector for reassembly.
    • Lift the black flaps and gently pull the strip out.
    • Set the strip aside.
    FixBot'a Sor
    Yorum Ekle
  9. HP Chromebook 14-Q010DX Hard drive Replacement: adım 9, 3 resimden 1. HP Chromebook 14-Q010DX Hard drive Replacement: adım 9, 3 resimden 2. HP Chromebook 14-Q010DX Hard drive Replacement: adım 9, 3 resimden 3.
    • Remove the screw.
    • Use your fingers to pull the white tab out of the black slot above the battery.
    FixBot'a Sor
    Yorum Ekle
  10. HP Chromebook 14-Q010DX Hard drive Replacement: adım 10, 1 resimden 1.
    • Gently remove battery.
    FixBot'a Sor
    Yorum Ekle
  11. HP Chromebook 14-Q010DX Hard drive Replacement, Bluetooth and Wireless Card: adım 11, 2 resimden 1. HP Chromebook 14-Q010DX Hard drive Replacement, Bluetooth and Wireless Card: adım 11, 2 resimden 2.
    • Using a spudger, remove the white and black cables from the card.
    FixBot'a Sor
    Yorum Ekle
  12. HP Chromebook 14-Q010DX Hard drive Replacement: adım 12, 2 resimden 1. HP Chromebook 14-Q010DX Hard drive Replacement: adım 12, 2 resimden 2.
    • Remove screw from card.
    FixBot'a Sor
    Yorum Ekle
  13. HP Chromebook 14-Q010DX Hard drive Replacement: adım 13, 1 resimden 1.
    • Gently pull card at a 45° angle to remove it.
    FixBot'a Sor
    Yorum Ekle
  14. HP Chromebook 14-Q010DX Hard drive Replacement, USB/SD card: adım 14, 2 resimden 1. HP Chromebook 14-Q010DX Hard drive Replacement, USB/SD card: adım 14, 2 resimden 2.
    • Remove screw indicated by the red circle at the top of the card port.
    FixBot'a Sor
    Yorum Ekle
  15. HP Chromebook 14-Q010DX Hard drive Replacement: adım 15, 1 resimden 1.
    • Gently remove the USB/SD card port.
    FixBot'a Sor
    Yorum Ekle
  16. HP Chromebook 14-Q010DX Hard drive Replacement, Fan replacement for a HP Chromebook: adım 16, 3 resimden 1. HP Chromebook 14-Q010DX Hard drive Replacement, Fan replacement for a HP Chromebook: adım 16, 3 resimden 2. HP Chromebook 14-Q010DX Hard drive Replacement, Fan replacement for a HP Chromebook: adım 16, 3 resimden 3.
    • Remove the 3 screws around the fan.
    • Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  17. HP Chromebook 14-Q010DX Hard drive Replacement: adım 17, 1 resimden 1.
    • Once the cable connecting the fan to the motherboard is revomed gently remove fan with hands.
    FixBot'a Sor
    Yorum Ekle
  18. HP Chromebook 14-Q010DX Hard drive Replacement, Motherboard: adım 18, 2 resimden 1. HP Chromebook 14-Q010DX Hard drive Replacement, Motherboard: adım 18, 2 resimden 2.
    • Using your fingers or spudger, pull out the connector.
    FixBot'a Sor
    Yorum Ekle
  19. HP Chromebook 14-Q010DX Hard drive Replacement: adım 19, 3 resimden 1. HP Chromebook 14-Q010DX Hard drive Replacement: adım 19, 3 resimden 2. HP Chromebook 14-Q010DX Hard drive Replacement: adım 19, 3 resimden 3.
    • Remove all of the indicated screws.
    • Pull up on black strip to remove the monitor cord.
    FixBot'a Sor
    Yorum Ekle
  20. HP Chromebook 14-Q010DX Hard drive Replacement: adım 20, 1 resimden 1.
    • Gently remove motherboard.
    FixBot'a Sor
    Yorum Ekle
  21. HP Chromebook 14-Q010DX Hard drive Replacement, Hard drive: adım 21, 1 resimden 1.
    • Flip motherboard over.
    FixBot'a Sor
    Yorum Ekle
  22. HP Chromebook 14-Q010DX Hard drive Replacement: adım 22, 1 resimden 1.
    • Remove the screw indicated by the red circle.
    FixBot'a Sor
    Yorum Ekle
  23. HP Chromebook 14-Q010DX Hard drive Replacement: adım 23, 1 resimden 1.
    • Remove the hard drive by pulling the device from the black slot.
    FixBot'a Sor
    Yorum Ekle
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Kevin Piper
1.602 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-2, Watkins Winter 2015 USF Tampa, Team 17-2, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S17G2
4 Üyeler
8 adet Kılavuz yazıldı
5Kılavuz Yorumları
Thanks so much for your clearly , detailed and easy to follow guide, nice job!
pedro munoz - Yanıt Paylaş
Buenas tarde y despuesnde quitar el disco duro que se hace se cambia por otro igual o que modelo
chaffa_45 - Yanıt Paylaş
Can you add more storage on the HP Chromebook 14 SMB about 500GB. I also want to know if the Chromebook can run Windows 10 without any problems.
Fire Alarm Collector - Yanıt Paylaş
Useful. Wish I would have read it B4 I started this project.
Maria Jones - Yanıt Paylaş
how do i upgrde my chrom browser?
Danielle Curtis - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 30
Son 30 gün: 94
Her zaman: 22,520
