Ana içeriğe geç
HP Chromebook 14-Q010DX Speaker Replacement
Neye ihtiyacın var
  1. HP Chromebook 14-Q010DX Speaker Replacement, Keyboard and Touchpad: adım 1, 2 resimden 1. HP Chromebook 14-Q010DX Speaker Replacement, Keyboard and Touchpad: adım 1, 2 resimden 2.
    • Flip the laptop so the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew the 13 screws.
    FixBot'a Sor
    Yorum Ekle
  2. HP Chromebook 14-Q010DX Speaker Replacement: adım 2, 3 resimden 1. HP Chromebook 14-Q010DX Speaker Replacement: adım 2, 3 resimden 2. HP Chromebook 14-Q010DX Speaker Replacement: adım 2, 3 resimden 3.
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. HP Chromebook 14-Q010DX Speaker Replacement: adım 3, 3 resimden 1. HP Chromebook 14-Q010DX Speaker Replacement: adım 3, 3 resimden 2. HP Chromebook 14-Q010DX Speaker Replacement: adım 3, 3 resimden 3.
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
    FixBot'a Sor
    Yorum Ekle
  4. HP Chromebook 14-Q010DX Speaker Replacement: adım 4, 1 resimden 1.
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
    FixBot'a Sor
    Yorum Ekle
  5. HP Chromebook 14-Q010DX Speaker Replacement: adım 5, 1 resimden 1.
    • Set aside the detached keyboard.
    FixBot'a Sor
    Yorum Ekle
  6. HP Chromebook 14-Q010DX Speaker Replacement, Speaker: adım 6, 3 resimden 1. HP Chromebook 14-Q010DX Speaker Replacement, Speaker: adım 6, 3 resimden 2. HP Chromebook 14-Q010DX Speaker Replacement, Speaker: adım 6, 3 resimden 3.
    • Undo the black tape located on the bottom from the frame of the laptop.
    • Using fingers or the spudger, slide out the black connector indicated on the left.
    • Use a #00 screwdriver to remove the two screws.
    FixBot'a Sor
    Yorum Ekle
  7. HP Chromebook 14-Q010DX Speaker Replacement: adım 7, 2 resimden 1. HP Chromebook 14-Q010DX Speaker Replacement: adım 7, 2 resimden 2.
    • Gently remove the speakers.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Brandon Nolen
3.536 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 17-2, Watkins Winter 2015 USF Tampa, Team 17-2, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S17G2
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 36
Her zaman: 1,476
