Ana içeriğe geç
HP Chromebook 14-Q070NR Battery Replacement
Neye ihtiyacın var
  1. HP Chromebook 14-Q070NR Battery Replacement, Keyboard: adım 1, 1 resimden 1.
    • At this point, the white caps that hide the top-most screws marked with red circles have been removed.
    • Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
    • After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
  2. HP Chromebook 14-Q070NR Battery Replacement: adım 2, 3 resimden 1. HP Chromebook 14-Q070NR Battery Replacement: adım 2, 3 resimden 2. HP Chromebook 14-Q070NR Battery Replacement: adım 2, 3 resimden 3.
    • Open the laptop and place it upright. Remove the keyboard from the device using a plastic spudger or opening tool.
    • Carefully remove as there are ribbons attached to the keyboard that is connected to the components inside.
    • Gently lift the keyboard just enough to expose the ribbons.
  3. HP Chromebook 14-Q070NR Battery Replacement: adım 3, 3 resimden 1. HP Chromebook 14-Q070NR Battery Replacement: adım 3, 3 resimden 2. HP Chromebook 14-Q070NR Battery Replacement: adım 3, 3 resimden 3.
    • Hold the keyboard up to remove the ribbons from the circuit board.
    • To remove each individual ribbon, grab the blue portion of each ribbon and pull it towards your direction until it is fully detached.
  4. HP Chromebook 14-Q070NR Battery Replacement: adım 4, 3 resimden 1. HP Chromebook 14-Q070NR Battery Replacement: adım 4, 3 resimden 2. HP Chromebook 14-Q070NR Battery Replacement: adım 4, 3 resimden 3.
    • Once the ribbons are detached, remove the keyboard from the device.
  5. HP Chromebook 14-Q070NR Battery Replacement, Battery: adım 5, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the (2) two screws at the bottom of the device.
    • Once removed, separate the screws from previous ones. They are different!
  6. HP Chromebook 14-Q070NR Battery Replacement: adım 6, 2 resimden 1. HP Chromebook 14-Q070NR Battery Replacement: adım 6, 2 resimden 2.
    • Remove the taped flat wire from the top of the battery.
    • Carefully pull away the connector from the top of the battery to the motherboard.
  7. HP Chromebook 14-Q070NR Battery Replacement: adım 7, 1 resimden 1.
    • Carefully lift the battery and remove it from the device.
Sonuç
Andres Martinez
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S9-G5, Remmell Fall 2017 USF Tampa, Team S9-G5, Remmell Fall 2017 üyesi
USFT-REMMELL-F17S9G5
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 395
