Giriş
After following previous guides as preliminary steps to removing the battery, you should be able to locate the battery and begin disassembly. Make sure to keep the battery screws seperate from others as they unique.
Neye ihtiyacın var
Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
Using the Phillips #0 screwdriver, remove the (2) two screws at the bottom of the device.
There are threaded nuts underneath the two screw holes located in the center of the computer (white caps cover them). When I removed the screws, the two nuts became loose and I found them in the pan after I took the battery out. I could not reattach these screws upon reassembly because there were no threads they could screw into, so I ended up with two screws and two nuts left over after completion. Are you sure it is really necessary to remove these two center screws?
Thomas Badura - Yanıt
