Ana içeriğe geç
HP Chromebook 14-Q070NR Display Replacement
Neye ihtiyacın var
  1. HP Chromebook 14-Q070NR Display Replacement, Keyboard: adım 1, 1 resimden 1.
    • At this point, the white caps that hide the top-most screws marked with red circles have been removed.
    • Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
    • After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
  2. HP Chromebook 14-Q070NR Display Replacement: adım 2, 3 resimden 1. HP Chromebook 14-Q070NR Display Replacement: adım 2, 3 resimden 2. HP Chromebook 14-Q070NR Display Replacement: adım 2, 3 resimden 3.
    • Open the laptop and place it upright. Remove the keyboard from the device using a plastic spudger or opening tool.
    • Carefully remove as there are ribbons attached to the keyboard that is connected to the components inside.
    • Gently lift the keyboard just enough to expose the ribbons.
  3. HP Chromebook 14-Q070NR Display Replacement: adım 3, 3 resimden 1. HP Chromebook 14-Q070NR Display Replacement: adım 3, 3 resimden 2. HP Chromebook 14-Q070NR Display Replacement: adım 3, 3 resimden 3.
    • Hold the keyboard up to remove the ribbons from the circuit board.
    • To remove each individual ribbon, grab the blue portion of each ribbon and pull it towards your direction until it is fully detached.
  4. HP Chromebook 14-Q070NR Display Replacement: adım 4, 3 resimden 1. HP Chromebook 14-Q070NR Display Replacement: adım 4, 3 resimden 2. HP Chromebook 14-Q070NR Display Replacement: adım 4, 3 resimden 3.
    • Once the ribbons are detached, remove the keyboard from the device.
  5. HP Chromebook 14-Q070NR Display Replacement, Display: adım 5, 1 resimden 1.
    • Unplug the cable located in the upper left corner of the device.
  6. HP Chromebook 14-Q070NR Display Replacement: adım 6, 1 resimden 1.
    • Remove these tabs located at each of the bottom corners of the display.
    • It is not necessary for the display to be completely removed from the device in order to complete this guide.
    • Using the Phillips #1 screwdriver, remove the single screw located under each of the two tabs.
  7. HP Chromebook 14-Q070NR Display Replacement: adım 7, 1 resimden 1.
    • Insert the plastic opening tool and work it around the entire frame of the display.
  8. HP Chromebook 14-Q070NR Display Replacement: adım 8, 2 resimden 1. HP Chromebook 14-Q070NR Display Replacement: adım 8, 2 resimden 2.
    • As you work the plastic opening tool around the edge, remove the front frame of the device.
  9. HP Chromebook 14-Q070NR Display Replacement: adım 9, 3 resimden 1. HP Chromebook 14-Q070NR Display Replacement: adım 9, 3 resimden 2. HP Chromebook 14-Q070NR Display Replacement: adım 9, 3 resimden 3.
    • Using the Phillips #1 screwdriver, remove the (4) four screws located at the bottom of the display.
    • Once the screws are removed, lift the display out of the device.
Sonuç
Richard Underwood
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S9-G5, Remmell Fall 2017 USF Tampa, Team S9-G5, Remmell Fall 2017 üyesi
USFT-REMMELL-F17S9G5
5 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
This was very helpful, I broke the screen to my chromebook whilst shutting the lid and the screen cracked. I didn’t want to spend the money on a new screen so I decided to take the whole top half off the chomebook and basically make a chromebox.
quardpd - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 286
