Ana içeriğe geç
HP Chromebook 14-ak013dx Internal Speaker Replacement
Neye ihtiyacın var
  1. HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: adım 1, 3 resimden 1. HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: adım 1, 3 resimden 2. HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: adım 1, 3 resimden 3.
    • Starting with the laptop on its back, remove the 13 screws holding the keyboard in place with a P00 screwdriver (2 screws are hidden behind the rubber footers)
    • Open the screen, revealing the keyboard. Using a prying tool, 'pop' the keyboard out by sliding the tool around the edge
  2. HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: adım 2, 3 resimden 1. HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: adım 2, 3 resimden 2. HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: adım 2, 3 resimden 3.
    • Gently raise the keyboard from the body, careful not to rip out the ribbons
    • With light pressure, flip the black bar holding the ribbons in place, and remove the ribbons from the body
  3. HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Keyboard: adım 3, 1 resimden 1.
    • Completely remove the keyboard, place away from the body of the laptop
  4. HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: adım 4, 3 resimden 1. HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: adım 4, 3 resimden 2. HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: adım 4, 3 resimden 3.
    • With a P00 Screwdriver, remove the 9 screws holding the battery in place
    • Gently pry the cable connecting the battery to the motherboard off
    • Battery will lift away from the body (screen will now be heavier than the body, be careful not to drop it)
  5. HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Left Speaker: adım 5, 2 resimden 1. HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Left Speaker: adım 5, 2 resimden 2.
    • Gently disconnect the cable connecting the internal speaker to the motherboard
    • Using a P00 Screwdriver, remove the final screw from the left speaker
    • Using a prying tool, carefully remove the speaker out of the body
  6. HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Right Speaker: adım 6, 2 resimden 1. HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Right Speaker: adım 6, 2 resimden 2.
    • With a P00 Screwdriver, remove the final screw from the right speaker
    • Carefully remove the right internal speaker from the body
    • The entire speaker (barring some tape you may need to remove) should lift away from the body of the laptop
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cameron C Blanchard
524 İtibar
4 adet Kılavuz yazıldı
Ekip
dwsad dwsad üyesi
Community
1 Üye
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 70
