Giriş
This guide will outline the process to replace a HP Chromebook keyboard in the event when the keyboard is no longer functional and/or to access the hardware underneath the keyboard for an in depth inspection.
Neye ihtiyacın var
You will need a pair of tweezers and a Phillips screwdriver.
Remove eight 5mm Phillips #0 screws from the back cover of the laptop.
To reassemble your device, simply follow the steps in reverse. Make sure you replace all screws that were originally removed. Then check that the keyboard is correctly snapped back in place.
