Ana içeriğe geç
HP Chromebook 14-ca061dx Display Replacement
Neye ihtiyacın var
  1. HP Chromebook 14-ca061dx Display Replacement, Display: adım 1, 3 resimden 1. HP Chromebook 14-ca061dx Display Replacement, Display: adım 1, 3 resimden 2. HP Chromebook 14-ca061dx Display Replacement, Display: adım 1, 3 resimden 3.
    • Flip the Chromebook so that the underside is facing upwards.
    • Follow along the edge with the iFixit opening tool to unhinge the display frame.
  2. HP Chromebook 14-ca061dx Display Replacement: adım 2, 1 resimden 1.
    • Flip the Chromebook right side up and open it to form a 180 degree angle.
  3. HP Chromebook 14-ca061dx Display Replacement: adım 3, 1 resimden 1.
    • Use the iFixit opening tool to pry open the bezel. Start from the bottom of the screen and work your way around the sides.
    • The bottom edge of the bezel may stick because there is glue holding it together.
  4. HP Chromebook 14-ca061dx Display Replacement: adım 4, 2 resimden 1. HP Chromebook 14-ca061dx Display Replacement: adım 4, 2 resimden 2.
    • Use spudger or the iFixit opening tool to remove the bezel.
    • When prying, be careful not to damage or snap bezel. This is made up of very, thin plastic.
    • Pull bezel from the bottom, once all clips are detached.
    • Remove bezel.
  5. HP Chromebook 14-ca061dx Display Replacement: adım 5, 2 resimden 1. HP Chromebook 14-ca061dx Display Replacement: adım 5, 2 resimden 2.
    • Remove the four 2mm JIS #000 screws.
  6. HP Chromebook 14-ca061dx Display Replacement: adım 6, 2 resimden 1. HP Chromebook 14-ca061dx Display Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to pull the tape back and remove the connector attached to the back of the LCD panel.
    • Be cautious when pulling back the tape—the connector/ribbon is fragile and could snap easily.
  7. HP Chromebook 14-ca061dx Display Replacement: adım 7, 1 resimden 1.
    • Remove the LCD/display panel from the Chromebook frame.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jean Arevalo
778 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G5, Barthe Fall 2019 UMass Dartmouth, Team S2-G5, Barthe Fall 2019 üyesi
UMASSD-BARTHE-F19S2G5
3 Üyeler
Bir Yorum
should disconnect the laptop battery first
TJ Kleckner - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 2,619
