Ana içeriğe geç
HP Chromebook 14-q010nr Battery Replacement
Neye ihtiyacın var
  1. HP Chromebook 14-q010nr Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Begin by turning the Chromebook onto its back.
    • Remove the 15 screws with a Phillips #0 screwdriver.
    • Four screws will be located underneath the device's rubber foot pads.
  2. HP Chromebook 14-q010nr Battery Replacement: adım 2, 3 resimden 1. HP Chromebook 14-q010nr Battery Replacement: adım 2, 3 resimden 2. HP Chromebook 14-q010nr Battery Replacement: adım 2, 3 resimden 3.
    • Remove the keyboard from the base plate with an opening pick to pry it open from both sides of the keyboard.
    • Beginning from the corners closest to the computer screen may result in easier disconnection.
  3. HP Chromebook 14-q010nr Battery Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the seven screws securing the battery.
  4. HP Chromebook 14-q010nr Battery Replacement: adım 4, 1 resimden 1.
    • Gently disconnect the battery's motherboard connection by pinching the white attachment and pulling the plug directly out of the port.
  5. HP Chromebook 14-q010nr Battery Replacement: adım 5, 2 resimden 1. HP Chromebook 14-q010nr Battery Replacement: adım 5, 2 resimden 2.
    • Before removing the battery, gently lift the white ribbon cable taped to the battery.
    • Gently pull up from the back of the battery to remove it.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 13
Her zaman: 132
