Ana içeriğe geç
HP Chromebook 14-x013dx I/O Board Replacement
Neye ihtiyacın var
  1. HP Chromebook 14-x013dx I/O Board Replacement, Keyboard, Touchpad: adım 1, 2 resimden 1. HP Chromebook 14-x013dx I/O Board Replacement, Keyboard, Touchpad: adım 1, 2 resimden 2.
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx I/O Board Replacement: adım 2, 1 resimden 1.
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx I/O Board Replacement: adım 3, 2 resimden 1. HP Chromebook 14-x013dx I/O Board Replacement: adım 3, 2 resimden 2.
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx I/O Board Replacement: adım 4, 2 resimden 1. HP Chromebook 14-x013dx I/O Board Replacement: adım 4, 2 resimden 2.
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx I/O Board Replacement: adım 5, 3 resimden 1. HP Chromebook 14-x013dx I/O Board Replacement: adım 5, 3 resimden 2. HP Chromebook 14-x013dx I/O Board Replacement: adım 5, 3 resimden 3.
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook 14-x013dx I/O Board Replacement, I/O Board: adım 6, 2 resimden 1. HP Chromebook 14-x013dx I/O Board Replacement, I/O Board: adım 6, 2 resimden 2.
    • Unhook the ribbon connecting the I/O board and the battery.
    • To remove the ribbon, lift the latch holding the ribbons in place and then pull them free.
  7. HP Chromebook 14-x013dx I/O Board Replacement: adım 7, 2 resimden 1. HP Chromebook 14-x013dx I/O Board Replacement: adım 7, 2 resimden 2.
    • Remove two 2mm screws from the I/O board using the Phillips PH00 screwdriver.
  8. HP Chromebook 14-x013dx I/O Board Replacement: adım 8, 1 resimden 1.
    • Lift the I/O board out of the laptop case.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
NHerbert
602 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G6, Nance Fall 2017 USF Tampa, Team S3-G6, Nance Fall 2017 üyesi
USFT-NANCE-F17S3G6
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 7
Her zaman: 456
