Ana içeriğe geç
HP Chromebook 14-x013dx Keyboard/Touchpad Replacement
Neye ihtiyacın var
  1. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement, Keyboard, Touchpad: adım 1, 2 resimden 1. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement, Keyboard, Touchpad: adım 1, 2 resimden 2.
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: adım 2, 1 resimden 1.
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: adım 3, 2 resimden 1. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: adım 3, 2 resimden 2.
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: adım 4, 2 resimden 1. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: adım 4, 2 resimden 2.
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: adım 5, 3 resimden 1. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: adım 5, 3 resimden 2. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: adım 5, 3 resimden 3.
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
NHerbert
602 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G6, Nance Fall 2017 USF Tampa, Team S3-G6, Nance Fall 2017 üyesi
USFT-NANCE-F17S3G6
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 1,294
