Ana içeriğe geç
HP Chromebook 14-x013dx Speakers Replacement
Neye ihtiyacın var
  1. HP Chromebook 14-x013dx Speakers Replacement, Keyboard, Touchpad: adım 1, 2 resimden 1. HP Chromebook 14-x013dx Speakers Replacement, Keyboard, Touchpad: adım 1, 2 resimden 2.
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx Speakers Replacement: adım 2, 1 resimden 1.
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx Speakers Replacement: adım 3, 2 resimden 1. HP Chromebook 14-x013dx Speakers Replacement: adım 3, 2 resimden 2.
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx Speakers Replacement: adım 4, 2 resimden 1. HP Chromebook 14-x013dx Speakers Replacement: adım 4, 2 resimden 2.
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx Speakers Replacement: adım 5, 3 resimden 1. HP Chromebook 14-x013dx Speakers Replacement: adım 5, 3 resimden 2. HP Chromebook 14-x013dx Speakers Replacement: adım 5, 3 resimden 3.
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook 14-x013dx Speakers Replacement, Battery: adım 6, 2 resimden 1. HP Chromebook 14-x013dx Speakers Replacement, Battery: adım 6, 2 resimden 2.
    • Remove the eight 4mm screws holding the battery in place using the Phillips #00 screwdriver.
  7. HP Chromebook 14-x013dx Speakers Replacement: adım 7, 2 resimden 1. HP Chromebook 14-x013dx Speakers Replacement: adım 7, 2 resimden 2.
    • Remove the ribbon cable that runs over the battery by lifting up the plastic latches and pulling the cable away.
  8. HP Chromebook 14-x013dx Speakers Replacement: adım 8, 2 resimden 1. HP Chromebook 14-x013dx Speakers Replacement: adım 8, 2 resimden 2.
    • Unhook the battery's power connector from the motherboard.
  9. HP Chromebook 14-x013dx Speakers Replacement: adım 9, 1 resimden 1.
    • Lift the battery out of the laptop case.
  10. HP Chromebook 14-x013dx Speakers Replacement, Speakers: adım 10, 2 resimden 1. HP Chromebook 14-x013dx Speakers Replacement, Speakers: adım 10, 2 resimden 2.
    • Unplug Speaker from motherboard.
  11. HP Chromebook 14-x013dx Speakers Replacement: adım 11, 2 resimden 1. HP Chromebook 14-x013dx Speakers Replacement: adım 11, 2 resimden 2.
    • Pull the left and right speaker out carefully.
    • The corners of the the speakers will be held in place by tape, and may require a bit of force.
  12. HP Chromebook 14-x013dx Speakers Replacement: adım 12, 2 resimden 1. HP Chromebook 14-x013dx Speakers Replacement: adım 12, 2 resimden 2.
    • Remove the black tape holding the wire to the laptop casing.
    • Remove the wires from the three hooks on the case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
NHerbert
602 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G6, Nance Fall 2017 USF Tampa, Team S3-G6, Nance Fall 2017 üyesi
USFT-NANCE-F17S3G6
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 7
Her zaman: 241
