Ana içeriğe geç
HP Chromebook 14-x015wm Battery Replacement
Neye ihtiyacın var
  1. HP Chromebook 14-x015wm Battery Replacement, Battery: adım 1, 2 resimden 1. HP Chromebook 14-x015wm Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the Chromebook upside down so that the bottom is facing upwards.
    • Remove the small rubber circles from all four corners.
    • Remove the other three rubber pads from the bottom
    • Proceed to unscrew all the screws.
    • Keep the screws on a magnetic mat or in a secure location and keep track of which screws went where.
  2. HP Chromebook 14-x015wm Battery Replacement: adım 2, 1 resimden 1.
    • Flip the laptop back over and open it so that the keyboard is revealed to you.
    • Use a plastic opening tool to pry off the keyboard. It's slightly difficult to get off, but go evenly around all four sides until it pops out.
    • Be careful of the ribbons underneath that connect the keyboard to the internal components.
  3. HP Chromebook 14-x015wm Battery Replacement: adım 3, 2 resimden 1. HP Chromebook 14-x015wm Battery Replacement: adım 3, 2 resimden 2.
    • The long, flat, black component that takes up the majority of the space is the battery.
    • All you are required to do is unscrew the screws attached to the battery and then gently remove the battery from the Chromebook.
    • Make sure to keep track of where the screws came from.
Sonuç
Cameron Sinclaire
201 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 1,738
