Giriş
We are going to help you remove and replace a component of your HP Chromebook CB2L. The component that this guide helps you with is the Audio Port of the HP Chromebook CB2L. Please take a look at this troubleshooting page to confirm that this component needs replacement.
Neye ihtiyacın var
Flip Chromebook over so that the bottom panel is facing upward.
Use the plastic opening tool to remove the blue panel.
Bir başkası bu kılavuzu tamamladı.
