Ana içeriğe geç
HP Chromebook CB2L Battery Replacement
Neye ihtiyacın var
  1. HP Chromebook CB2L Battery Replacement, Battery: adım 1, 2 resimden 1. HP Chromebook CB2L Battery Replacement, Battery: adım 1, 2 resimden 2.
    • First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
    • Next, using the plastic opening tool remove the blue panel.
    FixBot'a Sor
    Yorum Ekle
  2. HP Chromebook CB2L Battery Replacement: adım 2, 3 resimden 1. HP Chromebook CB2L Battery Replacement: adım 2, 3 resimden 2. HP Chromebook CB2L Battery Replacement: adım 2, 3 resimden 3.
    • Using the Phillips #1 screwdriver, remove the six 1.2mm screws.
    • Gently pry off the white back panel using the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  3. HP Chromebook CB2L Battery Replacement: adım 3, 1 resimden 1.
    • Disconnect the battery input to the motherboard using the plastic opening tool
    FixBot'a Sor
    Yorum Ekle
  4. HP Chromebook CB2L Battery Replacement: adım 4, 1 resimden 1.
    • Unscrew the four 1.2mm screws using the Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. HP Chromebook CB2L Battery Replacement: adım 5, 1 resimden 1.
    • Using the plastic opening tool remove the battery from the Chromebook.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Gregory Hinkson
352 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G6, Lacy Spring 2017 USF Tampa, Team S2-G6, Lacy Spring 2017 üyesi
USFT-LACY-S17S2G6
3 Üyeler
4 adet Kılavuz yazıldı
2Kılavuz Yorumları
the step about gently prying the underside of the laptop off made me snap off two screws under the thin blue rubber strip ! i see the holes they went in in the pictures in this guide. i understand that strip was glued on and it doesn't seem necessary to put those back (since i can't unglue the strip to put those screws back in) but.. yeah. it was unexpected and i thought i'd done something wrong.
katie - Yanıt Paylaş
Dont forget there are two screws underneath the small blue strip.
Roderick Wells - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 41
Her zaman: 1,782
