Ana içeriğe geç
Giriş
In this guide, we will be showing you how to remove the keyboard from your HP Chromebook CB2L.
  1. Flip the Chromebook over so the blue panels are showing.
    • Flip the Chromebook over so the blue panels are showing.
    • Starting in the top left or right corner, use the plastic opening tool to remove the large blue panel.
    • This piece has fragile plastic connectors. Don't damage them.
  2. Remove six 4.77mm screws using the Phillips #1 screwdriver. Remove six 4.77mm screws using the Phillips #1 screwdriver.
    • Remove six 4.77mm screws using the Phillips #1 screwdriver.
  3. Starting in the top right-hand corner of the exposed metal piece, use the blue plastic opening tool to remove the back panel. Starting in the top right-hand corner of the exposed metal piece, use the blue plastic opening tool to remove the back panel. Starting in the top right-hand corner of the exposed metal piece, use the blue plastic opening tool to remove the back panel.
    • Starting in the top right-hand corner of the exposed metal piece, use the blue plastic opening tool to remove the back panel.
  4. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  5. Remove twenty 3.42mm screws with the Phillips #1 screwdriver. Remove twenty 3.42mm screws with the Phillips #1 screwdriver.
    • Remove twenty 3.42mm screws with the Phillips #1 screwdriver.
  6. Remove the black and white antennae wires, the white ribbon cables, the large black connecter, and the speaker cable from the motherboard. Grabbing the boards by the edges, remove the motherboard and audio/USB board.
    • Remove the black and white antennae wires, the white ribbon cables, the large black connecter, and the speaker cable from the motherboard.
    • Grabbing the boards by the edges, remove the motherboard and audio/USB board.
  7. Remove the red and blue antennae wires from the SIM card board. Remove the SIM card tray. Flip the board over and use the plastic opening tool to remove the ribbon cable,  then remove the board.
    • Remove the red and blue antennae wires from the SIM card board.
    • Remove the SIM card tray.
    • Flip the board over and use the plastic opening tool to remove the ribbon cable, then remove the board.
  8. Remove the speakers and battery. Remove the speakers and battery.
    • Remove the speakers and battery.
  9. Remove eighteen 2.5mm screws using the Phillips #1 screwdriver. Flip the Chromebook so the top is on the table and the push out the keyboard from the back.
    • Remove eighteen 2.5mm screws using the Phillips #1 screwdriver.
    • Flip the Chromebook so the top is on the table and the push out the keyboard from the back.
Sonuç
Nathan Petrie
277 İtibar
2 adet Kılavuz yazıldı
Takım
IUPUI, Team S1-G4, Harley Fall 2018 IUPUI, Team S1-G4, Harley Fall 2018 üyesi
IUPUI-HARLEY-F18S1G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 61
