Giriş
In this guide we will remove the battery of your HP Chromebook x360 11-ae010nr for a battery replacement, if you device has a shortened battery life, slow charging times, overheating issues, and battery health warnings.
You will simply be removing screws and unplugging cables inside the device. I will walk you through a step-by-step process comprising nine carefully outlined steps.
Before starting, please be sure to have the necessary parts and tools and that your Chromebook is fully powered off.
Following these instructions will ensure a safe and effective removal procedure.
Neye ihtiyacın var
Flip the device upside down so that the screws are visible.
Loosen two captive Phillips #1 screws from the center of the device.
Remove three 9.3 mm Phillips #1 screws from the joint side of the device.
Remove four 6.1 mm Phillips #1 screws from the opening side of the device.
Insert an iFixit opening tool between the edge of the keyboard assembly and the base of the device.
Push down on the handle of the opening tool to create an opening between the keyboard assembly and the base of the device.
Move the opening tool around the device, popping open the clips with force when necessary, until the keyboard assembly is fully lifted from the base of the device.
Bir başkası bu kılavuzu tamamladı.
