Giriş
If the display on your HP Chromebook x360 11-ae010nr is broken or damaged and you wish to replace it then this guides for you. The guide will show a step-by-step process on how to disconnect the display from the rest of your device.
Neye ihtiyacın var
Flip the device upside down so that the screws are visible.
Loosen two captive Phillips #1 screws from the center of the device.
Remove three 9.3 mm Phillips #1 screws from the joint side of the device.
Remove four 6.1 mm Phillips #1 screws from the opening side of the device.
Insert an iFixit opening tool between the edge of the keyboard assembly and the base of the device.
Push down on the handle of the opening tool to create an opening between the keyboard assembly and the base of the device.
Move the opening tool around the device, popping open the clips with force when necessary, until the keyboard assembly is fully lifted from the base of the device.
Use a pair of tweezers to gently but firmly pull each of the black cables out from their sockets.
Bir başkası bu kılavuzu tamamladı.
