Giriş
This guide outlines how to remove the fan of an HP Chromebook x360 14c-ca0053. The fan functions to prevent the device from overheating, but it is fragile and susceptible to damage. If the device is overheating or making a whining sound, the fan likely needs to be replaced.
Neye ihtiyacın var
Use a Phillips #0 screwdriver to remove the four 3 mm screws that secure the heatsink.
Use a Phillips #0 screwdriver to remove the three 3 mm screws that secure the fan.
