Giriş
If the bottom cover of your HP Chromebox is damaged, it is easy to replace. This guide will take you through the steps of replacing the bottom cover. For this guide, you will need the Phillips #1 screwdriver and a plastic spudger.
Neye ihtiyacın var
Position the device upside-down on a flat, level surface with the USB ports facing you.
Bir başkası bu kılavuzu tamamladı.
both for the cover replacement and shield replacement
Ian Stoffel - Yanıt
For the hard drive replacement, a longer times should be indicated. for the WLAN replacement 15 minutes is indicated, but for the hard drive replacement, which can only be done after the WLAN replacement, the time is listed as 10 minutes.
Ian Stoffel - Yanıt
