Ana içeriğe geç
HP Chromebox J5N50UT System Board Replacement
  1. HP Chromebox J5N50UT System Board Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Before removing the bottom cover, ensure that your computer is powered down and ensure that all external devices are disconnected. If you are unsure whether the computer is off or in hibernation mode, turn the computer on, then shut it down through the operating system.
    • Position the device upside-down on a flat, level surface with the USB ports facing you.
  2. HP Chromebox J5N50UT System Board Replacement: adım 2, 1 resimden 1.
    • Using your metal spudger, lift and remove the 4 rubber “feet” from each corner.
  3. HP Chromebox J5N50UT System Board Replacement: adım 3, 1 resimden 1.
    • Using your Phillips head screwdriver, remove the four Phillips M2.5×4.0 screws that secure the bottom cover to the computer. In this step the usage of the magnetic mat will be helpful to keep up with the screws.
  4. HP Chromebox J5N50UT System Board Replacement: adım 4, 1 resimden 1.
    • Insert the flat end of your metal spudger under the bottom cover near the USB ports, then pry the bottom cover off the computer.
  5. HP Chromebox J5N50UT System Board Replacement, Bottom Shield: adım 5, 1 resimden 1.
    • Lift the two pieces of mylar tape from the bracket.
  6. HP Chromebox J5N50UT System Board Replacement: adım 6, 1 resimden 1.
    • Using your Phillips #1 screwdriver, remove the four Phillips M2.5×4.0 screws that hold the shield in place.
  7. HP Chromebox J5N50UT System Board Replacement: adım 7, 1 resimden 1.
    • Insert your spudger into the gap between the bottom shield and the ports and gently pry to lift and remove the shield.
  8. HP Chromebox J5N50UT System Board Replacement, WLAN Module: adım 8, 2 resimden 1. HP Chromebox J5N50UT System Board Replacement, WLAN Module: adım 8, 2 resimden 2.
    • Disconnect the white and black antenna cables from the module.
  9. HP Chromebox J5N50UT System Board Replacement: adım 9, 3 resimden 1. HP Chromebox J5N50UT System Board Replacement: adım 9, 3 resimden 2. HP Chromebox J5N50UT System Board Replacement: adım 9, 3 resimden 3.
    • Using your Phillips #1 screwdriver, remove the M2.0×3.0 screw from the upper left corner of the module.
    • Once the screw has been removed, the module will tilt up.
  10. HP Chromebox J5N50UT System Board Replacement: adım 10, 2 resimden 1. HP Chromebox J5N50UT System Board Replacement: adım 10, 2 resimden 2.
    • Remove the WLAN module by pulling it away from the slot at an angle.
  11. HP Chromebox J5N50UT System Board Replacement, Hard Drive: adım 11, 2 resimden 1. HP Chromebox J5N50UT System Board Replacement, Hard Drive: adım 11, 2 resimden 2.
    • Remove the Phillips M2.0×3.0 screw.
    • The hard drive will tilt up once the screw has been removed.
  12. HP Chromebox J5N50UT System Board Replacement: adım 12, 2 resimden 1. HP Chromebox J5N50UT System Board Replacement: adım 12, 2 resimden 2.
    • Pull the hard drive at an angle to remove it from its slot.
  13. HP Chromebox J5N50UT System Board Replacement, System Board: adım 13, 3 resimden 1. HP Chromebox J5N50UT System Board Replacement, System Board: adım 13, 3 resimden 2. HP Chromebox J5N50UT System Board Replacement, System Board: adım 13, 3 resimden 3.
    • Remove the four Phillips M2.5×4.0 screws by using the Phillips #1 Screwdriver, that secure the system board to the computer.
  14. HP Chromebox J5N50UT System Board Replacement: adım 14, 1 resimden 1.
    • Use the mylar tape to lift the system board out of the computer.
Sonuç
Ashley Marvin
661 İtibar
5 adet Kılavuz yazıldı
Ohio State, Team S1-G3, Whitney Fall 2018 Ohio State, Team S1-G3, Whitney Fall 2018 üyesi
OSU-WHITNEY-F18S1G3
2 Üyeler
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 910
