Ana içeriğe geç
HP Color LaserJet Pro MFP M277dw Power Button Replacement
Neye ihtiyacın var
  1. HP Color LaserJet Pro MFP M277dw Power Button Replacement, Power Button: adım 1, 3 resimden 1. HP Color LaserJet Pro MFP M277dw Power Button Replacement, Power Button: adım 1, 3 resimden 2. HP Color LaserJet Pro MFP M277dw Power Button Replacement, Power Button: adım 1, 3 resimden 3.
    • Lower the back panel by pulling it down.
    • Remove one Phillips #2 10mm screw.
    • Use the plastic opening tool to remove right side panel by prying it off.
    • Flipping the printer onto its side makes it easier to remove the side panel.
  2. HP Color LaserJet Pro MFP M277dw Power Button Replacement: adım 2, 2 resimden 1. HP Color LaserJet Pro MFP M277dw Power Button Replacement: adım 2, 2 resimden 2.
    • Lower the front panel by pulling it down from the upright position.
    • The button cover should come off with the panel, if it does not be sure to remove it.
  3. HP Color LaserJet Pro MFP M277dw Power Button Replacement: adım 3, 3 resimden 1. HP Color LaserJet Pro MFP M277dw Power Button Replacement: adım 3, 3 resimden 2. HP Color LaserJet Pro MFP M277dw Power Button Replacement: adım 3, 3 resimden 3.
    • Remove two Phillips #2 8mm screws.
    • Unplug the wire connecting the power button to the circuit board by gently pulling them apart.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christopher Fahey
744 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S4-G2, White Fall 2018 Cal Poly, Team S4-G2, White Fall 2018 üyesi
CPSU-WHITE-F18S4G2
3 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
How to make the catridge tray out ? As one side(left) of the tray is not coming out.
Ajay Kumar Singh - Yanıt
I am not sure if it’s the power button or power module. How do I determine that? Where do I get the parts?
Sheila Shook - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 47
Her zaman: 2,594
