Ana içeriğe geç
HP Compaq 2510p Bluetooth Adapter Replacement
Neye ihtiyacın var
  1. HP Compaq 2510p Bluetooth Adapter Replacement, Bluetooth Adapter: adım 1, 1 resimden 1.
    • Place the laptop upside down, with the battery facing away from you. Towards the bottom-middle of the laptop, you should see a small panel with a Bluetooth symbol.
  2. HP Compaq 2510p Bluetooth Adapter Replacement: adım 2, 1 resimden 1.
    • There is 1 screw on the panel you located in step one. Use your Philips head screwdriver to remove the single screw.
  3. HP Compaq 2510p Bluetooth Adapter Replacement: adım 3, 1 resimden 1.
    • Remove the Bluetooth panel by pulling it with your finger.
    • Pull gently as there is a wire connecting the laptop and the adapter.
  4. HP Compaq 2510p Bluetooth Adapter Replacement: adım 4, 1 resimden 1.
    • Pull the adapter to the left exposing its underside. Locate and remove its only screw using your Phillip's head screwdriver.
  5. HP Compaq 2510p Bluetooth Adapter Replacement: adım 5, 1 resimden 1.
    • Separate the Bluetooth adapter by pulling it from its casing.
  6. HP Compaq 2510p Bluetooth Adapter Replacement: adım 6, 1 resimden 1.
    • Remove the adapter by pulling on the base of the connecting wires and the adapter, in opposite directions.
    • Use moderate force.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Derek Kohansky
297 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 UMass Dartmouth, Team 3-8, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S3G8
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 8
Her zaman: 440
