Ana içeriğe geç
HP Compaq 2510p Power/audio bar Replacement
Neye ihtiyacın var
  1. HP Compaq 2510p Power/audio bar Replacement, Power/audio bar: adım 1, 1 resimden 1.
    • Locate the 4 screws in the four corners of the laptop screen.
    • The screws may be hidden underneath a small rubber pad.
    • Be sure to ground yourself and tools before working near electronics.
  2. HP Compaq 2510p Power/audio bar Replacement: adım 2, 1 resimden 1.
    • Use a Flathead screwdriver to remove the 4 rubber covers over the 4 screws referenced in step 1.
  3. HP Compaq 2510p Power/audio bar Replacement: adım 3, 1 resimden 1.
    • Once the rubber has been removed a screw will be revealed. Remove each of the four screws with your Philips head screwdriver.
  4. HP Compaq 2510p Power/audio bar Replacement: adım 4, 1 resimden 1.
    • Insert your spudger along the top of the screen, separating the plastic cover and the screen
  5. HP Compaq 2510p Power/audio bar Replacement: adım 5, 1 resimden 1.
    • Continue running your Flathead along the top of the screen until the top is completely separated.
  6. HP Compaq 2510p Power/audio bar Replacement: adım 6, 2 resimden 1. HP Compaq 2510p Power/audio bar Replacement: adım 6, 2 resimden 2.
    • Pull the plastic covering of the screen towards the keyboard, exposing the inner workings of the screen.
  7. HP Compaq 2510p Power/audio bar Replacement: adım 7, 1 resimden 1.
    • Locate the hinges at the bottom left, and right of the screen
  8. HP Compaq 2510p Power/audio bar Replacement: adım 8, 2 resimden 1. HP Compaq 2510p Power/audio bar Replacement: adım 8, 2 resimden 2.
    • Separate the Power/Audio bar from the hinge by gently pulling.
  9. HP Compaq 2510p Power/audio bar Replacement: adım 9, 1 resimden 1.
    • Flip the Power/Audio bar over exposing the ribbon wire and its connection to the Power/Audio bar.
  10. HP Compaq 2510p Power/audio bar Replacement: adım 10, 1 resimden 1.
    • Separate the ribbon wire by gently pulling the wire from its socket.
    • The wire will be separated and the bar is free.
    • Be gentle as you pull.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Derek Kohansky
297 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 UMass Dartmouth, Team 3-8, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S3G8
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 415
