Ana içeriğe geç
HP Compaq 2510p RAM Replacement
Neye ihtiyacın var
    1. HP Compaq 2510p RAM Replacement, RAM: adım 1, 1 resimden 1.
      • Flip the device over so the back panel is facing upwards. Locate the RAM plate cover towards the left side of the laptop. There will be two screws located on the panel.
      FixBot'a Sor
      Yorum Ekle
    2. HP Compaq 2510p RAM Replacement: adım 2, 1 resimden 1.
      • Remove both screws holding the RAM cover plate in place using your Phillips Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. HP Compaq 2510p RAM Replacement: adım 3, 1 resimden 1.
      • Remove the cover plate by lifting upwards once screws are removed.
      FixBot'a Sor
      Yorum Ekle
    4. HP Compaq 2510p RAM Replacement: adım 4, 1 resimden 1.
      • Carefully release the pins that are securing the RAM in place by pushing in a outward motion, away from the RAM.
      • Be sure to ground yourself before touching the RAM.
      • Be gentle when releasing the pins.
      FixBot'a Sor
      Yorum Ekle
    5. HP Compaq 2510p RAM Replacement: adım 5, 1 resimden 1.
      • Remove the old RAM by lifting it upwards, then pulling.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nathan Pereira
81 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 UMass Dartmouth, Team 3-8, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S3G8
3 Üyeler
59 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 1,167
