Ana içeriğe geç
HP Compaq 515 Keyboard Replacement
Neye ihtiyacın var
  1. HP Compaq 515 Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Turn the laptop over, the screws for the keyboard are in the middle and left of the device
    FixBot'a Sor
    Yorum Ekle
  2. HP Compaq 515 Keyboard Replacement: adım 2, 1 resimden 1.
    • Unscrew the two 0.725 cm Screws with a PH1 screwdriver bit
    • Make sure to put the screws in a safe place so you don't lose them
    FixBot'a Sor
    Yorum Ekle
  3. HP Compaq 515 Keyboard Replacement: adım 3, 1 resimden 1.
    • Flip the laptop over and open the screen
    FixBot'a Sor
    Yorum Ekle
  4. HP Compaq 515 Keyboard Replacement: adım 4, 2 resimden 1. HP Compaq 515 Keyboard Replacement: adım 4, 2 resimden 2.
    • Gently use a plastic spudger to remove the plastic holder at the top of the keyboard
    FixBot'a Sor
    Yorum Ekle
  5. HP Compaq 515 Keyboard Replacement: adım 5, 1 resimden 1.
    • Gently use a plastic spudger to remove the keyboard from its holders
    • Be careful as there is a wire connecting the keyboard to the laptop
    FixBot'a Sor
    Yorum Ekle
  6. HP Compaq 515 Keyboard Replacement: adım 6, 1 resimden 1.
    • Carefully unclip and remove the large black wire that is connecting the keyboard to the laptop
    FixBot'a Sor
    Yorum Ekle
Sonuç
Kirsten Harnden
259 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G1, Covino Spring 2018 UMass Dartmouth, Team S4-G1, Covino Spring 2018 üyesi
UMASSD-COVINO-S18S4G1
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 733
