Ana içeriğe geç
HP Compaq 515 RAM Replacement
Neye ihtiyacın var
  1. HP Compaq 515 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Turn the laptop over. The screw for the RAM is located in the middle of the device.
    FixBot'a Sor
    Yorum Ekle
  2. HP Compaq 515 RAM Replacement: adım 2, 1 resimden 1.
    • Unscrew the small screw using a PH00 bit.
    • The screw is held in place, so there is no need to worry about losing it.
    FixBot'a Sor
    Yorum Ekle
  3. HP Compaq 515 RAM Replacement: adım 3, 2 resimden 1. HP Compaq 515 RAM Replacement: adım 3, 2 resimden 2.
    • There are two tabs on either side of the RAM card that are holding it in place. Slide them to the sides; one to the left and the other to the right. The RAM pops out.
    FixBot'a Sor
    Yorum Ekle
  4. HP Compaq 515 RAM Replacement: adım 4, 1 resimden 1.
    • Slide the RAM card out of its socket.
    FixBot'a Sor
    Yorum Ekle
  5. HP Compaq 515 RAM Replacement: adım 5, 1 resimden 1.
    • Repeat these steps for the second RAM card which is stored underneath the first one.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Aleks B
337 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G1, Covino Spring 2018 UMass Dartmouth, Team S4-G1, Covino Spring 2018 üyesi
UMASSD-COVINO-S18S4G1
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 645
