Neye ihtiyacın var
Flip the computer over so the backside is facing you.
Using the two prongs that are located in the back, slide the further left prong and the upper right prong to the left as indicated in the image.
Slide the battery out.
Look for tabs in between esc and f1, f4 and f5, f8 and f9, f12 and scroll.
Pull these tabs towards you.
Flip the laptop over and on the back of the center of the keyboard there is a screw with a rectangle beside it that looks like a keyboard. Remove this Phillips 5mm screw and another similar screw in the back top left of the keyboard.
Then carefully lift the keyboard out of place with your fingernails or a plastic opening tool.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
I don’t know why these instructions are suggested but this is how you actually remove the disc drive. https://www.youtube.com/watch?v=gTvAt3Nn...
