Ana içeriğe geç
HP Compaq 6510b Fan Replacement
Neye ihtiyacın var
  1. HP Compaq 6510b Fan Replacement, Battery: adım 1, 2 resimden 1. HP Compaq 6510b Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the computer over so the backside is facing you.
    • Using the two prongs that are located in the back, slide the further left prong and the upper right prong to the left as indicated in the image.
    • Slide the battery out.
  2. HP Compaq 6510b Fan Replacement, RAM: adım 2, 2 resimden 1. HP Compaq 6510b Fan Replacement, RAM: adım 2, 2 resimden 2.
    • Flip your device over.
    • In the center of the bottom of the laptop, there is a panel with two screws. Using the JIS #1 screw head unscrew both.
    • Lift the panel.
  3. HP Compaq 6510b Fan Replacement: adım 3, 3 resimden 1. HP Compaq 6510b Fan Replacement: adım 3, 3 resimden 2. HP Compaq 6510b Fan Replacement: adım 3, 3 resimden 3.
    • The RAM is held down by two prongs. Gently pull them until the RAM pops out of place.
    • Lift the RAM out of place.
  4. HP Compaq 6510b Fan Replacement, Fan: adım 4, 1 resimden 1.
    • Look for tabs in between esc and f1, f4 and f5, f8 and f9, f12 and scroll.
    • Pull these tabs towards you.
  5. HP Compaq 6510b Fan Replacement: adım 5, 2 resimden 1. HP Compaq 6510b Fan Replacement: adım 5, 2 resimden 2.
    • Flip the laptop over and on the back of the center of the keyboard there is a screw with a rectangle beside it that looks like a keyboard. Remove this Phillips 5mm screw and another similar screw in the back top left of the keyboard.
    • Then carefully lift the keyboard out of place with your fingernails or a plastic opening tool.
  6. HP Compaq 6510b Fan Replacement: adım 6, 3 resimden 1. HP Compaq 6510b Fan Replacement: adım 6, 3 resimden 2. HP Compaq 6510b Fan Replacement: adım 6, 3 resimden 3.
    • There will be a metallic film attached to the keyboard from the motherboard. A black latch runs along the film keeping it in place. Lift the latch and detach the film; remove it to fully remove the keyboard.
  7. HP Compaq 6510b Fan Replacement: adım 7, 3 resimden 1. HP Compaq 6510b Fan Replacement: adım 7, 3 resimden 2. HP Compaq 6510b Fan Replacement: adım 7, 3 resimden 3.
    • Carefully undo the white film the same way you took out the metallic film
    • Once this film is removed the bar with the power button and media tools above the keyboard will pop out of place using a spudger.
  8. HP Compaq 6510b Fan Replacement: adım 8, 2 resimden 1. HP Compaq 6510b Fan Replacement: adım 8, 2 resimden 2.
    • Underneath, a metal clamp will be revealed with two Torx Security T7 17mm screws. Unscrew these.
    • Carefully lift the cable out of place that is to the right of it.
  9. HP Compaq 6510b Fan Replacement: adım 9, 2 resimden 1. HP Compaq 6510b Fan Replacement: adım 9, 2 resimden 2.
    • Unscrew these two JIS #1 5mm screws on the fan.
    • Carefully unplug the fans' wires.
    • Remove the fan and put in new one.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Joseph Noudom
569 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G5, Simcock Spring 2018 UMass Dartmouth, Team S2-G5, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S2G5
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Many Thanks!
BTW, my German keyboard was held by a 3rd screw. In step 3, one needs to remove the remaining screw next to the WIFI module as well.
Torsten Spengler - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 11
Her zaman: 1,138
