Ana içeriğe geç
HP Compaq 6510b Hard Drive Replacement
Neye ihtiyacın var
  1. HP Compaq 6510b Hard Drive Replacement, Battery: adım 1, 2 resimden 1. HP Compaq 6510b Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the computer over so the backside is facing you.
    • Using the two prongs that are located in the back, slide the further left prong and the upper right prong to the left as indicated in the image.
    • Slide the battery out.
  2. HP Compaq 6510b Hard Drive Replacement, Hard Drive: adım 2, 3 resimden 1. HP Compaq 6510b Hard Drive Replacement, Hard Drive: adım 2, 3 resimden 2. HP Compaq 6510b Hard Drive Replacement, Hard Drive: adım 2, 3 resimden 3.
    • Flip the laptop over and locate the sign that says HP 3D DriveGuard.
    • Remove the two 5mm JIS #1 screws with your screwdriver.
    • Carefully lift up the cover.
    • Carefully lift up the hard drive from the back and pull it out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Joseph Noudom
569 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G5, Simcock Spring 2018 UMass Dartmouth, Team S2-G5, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S2G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 18
Her zaman: 896
