Ana içeriğe geç
HP Compaq 6710b Keyboard Replacement
Neye ihtiyacın var
  1. HP Compaq 6710b Keyboard Replacement, Keyboard: adım 1, 3 resimden 1. HP Compaq 6710b Keyboard Replacement, Keyboard: adım 1, 3 resimden 2. HP Compaq 6710b Keyboard Replacement, Keyboard: adım 1, 3 resimden 3.
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
    FixBot'a Sor
    Yorum Ekle
  2. HP Compaq 6710b Keyboard Replacement: adım 2, 1 resimden 1.
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
    FixBot'a Sor
    Yorum Ekle
  3. HP Compaq 6710b Keyboard Replacement: adım 3, 2 resimden 1. HP Compaq 6710b Keyboard Replacement: adım 3, 2 resimden 2.
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
    FixBot'a Sor
    Yorum Ekle
  4. HP Compaq 6710b Keyboard Replacement: adım 4, 1 resimden 1.
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Khulan Orgil
1.186 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-2, Maness Spring 2015 Cal Poly, Team 4-2, Maness Spring 2015 üyesi
CPSU-MANESS-S15S4G2
4 Üyeler
2Kılavuz Yorumları
No parts required to *replace* the keyboard?
David - Yanıt Paylaş
Did you really need to be told to get a keyboard part to do a keyboard replacement?
Thanks for the guide
Victor Izquierdo Quesada - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 48
Her zaman: 5,724
