Ana içeriğe geç
HP Compaq 6710b Keyboard Replacement
Neye ihtiyacın var
  1. HP Compaq 6710b Keyboard Replacement, Keyboard: adım 1, 3 resimden 1. HP Compaq 6710b Keyboard Replacement, Keyboard: adım 1, 3 resimden 2. HP Compaq 6710b Keyboard Replacement, Keyboard: adım 1, 3 resimden 3.
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
  2. HP Compaq 6710b Keyboard Replacement: adım 2, 1 resimden 1.
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
  3. HP Compaq 6710b Keyboard Replacement: adım 3, 2 resimden 1. HP Compaq 6710b Keyboard Replacement: adım 3, 2 resimden 2.
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
  4. HP Compaq 6710b Keyboard Replacement: adım 4, 1 resimden 1.
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Khulan Orgil
1.171 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-2, Maness Spring 2015 Cal Poly, Team 4-2, Maness Spring 2015 üyesi
CPSU-MANESS-S15S4G2
4 Üyeler
2 Yorum
No parts required to *replace* the keyboard?
David - Yanıt
Did you really need to be told to get a keyboard part to do a keyboard replacement?
Thanks for the guide
Victor Izquierdo Quesada - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 5,017
