Giriş
Remove the power button panel from above the keyboard.
Neye ihtiyacın var
Flip to the backside of the laptop.
Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
Using the same screwdriver, unscrew the 8mm screws.
Put a finger under each side of the plastic lock on the ribbon cable and pull up.
4 farklı kişi bu kılavuzu tamamladı.
