Ana içeriğe geç
HP Compaq 6730b Switch Cover Replacement
Neye ihtiyacın var
  1. HP Compaq 6730b Switch Cover Replacement, Switch Cover: adım 1, 3 resimden 1. HP Compaq 6730b Switch Cover Replacement, Switch Cover: adım 1, 3 resimden 2. HP Compaq 6730b Switch Cover Replacement, Switch Cover: adım 1, 3 resimden 3.
    • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer.
    • Close the screen and turn the computer over. Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the computer. They are secured by a spring clip at the back, so they will not be easily removed. All that is required is to loosen those.
    • Turn the computer display-side up, with the front toward you. Open the computer as far as possible. There are four retention tabs that hold the keyboard down.
  2. HP Compaq 6730b Switch Cover Replacement: adım 2, 3 resimden 1. HP Compaq 6730b Switch Cover Replacement: adım 2, 3 resimden 2. HP Compaq 6730b Switch Cover Replacement: adım 2, 3 resimden 3.
    • Use a small screwdriver, or other instrument, to slide the four tabs in a downward direction toward the palmrest.
    • Gently lift the keyboard up from the display side,
    • and tilt it toward the front of the computer. Do not lift it up to fast or to high, the keyboard ribbon cable is still connected
  3. HP Compaq 6730b Switch Cover Replacement: adım 3, 3 resimden 1. HP Compaq 6730b Switch Cover Replacement: adım 3, 3 resimden 2. HP Compaq 6730b Switch Cover Replacement: adım 3, 3 resimden 3.
    • Here is the keyboard ribbon cable seated in the zero insertion force (Zif) connector. The keyboard is now separated and can now be removed.
    • Release the Zif connector to which the power button board cable is connected, by lifting the clasp of the Zif connector in an upward direction.
    • Lift the left and right sides of the switch cover until it detaches from the computer, but do not yet try to remove it.
  4. HP Compaq 6730b Switch Cover Replacement: adım 4, 2 resimden 1. HP Compaq 6730b Switch Cover Replacement: adım 4, 2 resimden 2.
    • The LED board cable is still attached, disconnect it from the Zif connector by simply pulling it out in an upward direction.
    • With both ribbon cables disconnected, remove the switch cover.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
oldturkey03
812.794 İtibar
119 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
45 Üyeler
702 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,424
