Ana içeriğe geç
HP Compaq 6910p Processor Replacement
Neye ihtiyacın var
    1. HP Compaq 6910p Processor Replacement, Processor: adım 1, 2 resimden 1. HP Compaq 6910p Processor Replacement, Processor: adım 1, 2 resimden 2.
      • Turn the laptop upside down.
      • Remove the fourteen 1.5 cm Phillips's #1 screws.
      • Remove the battery.
      • Remove three 0.3 cm Phillips #1 screws in the battery compartment.
      FixBot'a Sor
      Yorum Ekle
    2. HP Compaq 6910p Processor Replacement: adım 2, 3 resimden 1. HP Compaq 6910p Processor Replacement: adım 2, 3 resimden 2. HP Compaq 6910p Processor Replacement: adım 2, 3 resimden 3.
      • Slide the tabs upward to release the keyboard
      • Lift up the keyboard
      • Disconnect the cables attaching the keyboard to the laptop by lifting up the release tabs.
      • Use a spudger if you're having trouble lifting up the tabs.
      FixBot'a Sor
      Yorum Ekle
    3. HP Compaq 6910p Processor Replacement: adım 3, 1 resimden 1.
      • Remove the upper frame of the laptop
      • This part is difficult, so use a spudger if you're having trouble removing the frame.
      FixBot'a Sor
      Yorum Ekle
    4. HP Compaq 6910p Processor Replacement: adım 4, 3 resimden 1. HP Compaq 6910p Processor Replacement: adım 4, 3 resimden 2. HP Compaq 6910p Processor Replacement: adım 4, 3 resimden 3.
      • Loosen the four 1.5 cm Phillips #1 screws indicated in red.
      • Remove the heat sink to reveal the processor.
      FixBot'a Sor
      Yorum Ekle
    5. HP Compaq 6910p Processor Replacement: adım 5, 1 resimden 1.
      • Lift up the processor carefully to remove
      FixBot'a Sor
      Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Tyler Fricks
531 İtibar
5 adet Kılavuz yazıldı
Ekip
Montana Tech, Team 3-2, Shirk Fall 2015 Montana Tech, Team 3-2, Shirk Fall 2015 üyesi
MTUM-SHIRK-F15S3G2
5 Üyeler
60 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 14
Son 30 gün: 38
Her zaman: 5,192
