Ana içeriğe geç
HP Compaq 6910p RAM Replacement
Neye ihtiyacın var
    1. HP Compaq 6910p RAM Replacement, RAM: adım 1, 2 resimden 1. HP Compaq 6910p RAM Replacement, RAM: adım 1, 2 resimden 2.
      • Loosen the 1.5 cm Phillips #1 screw.
      • Lift up the cover.
      FixBot'a Sor
      Yorum Ekle
    2. HP Compaq 6910p RAM Replacement: adım 2, 3 resimden 1. HP Compaq 6910p RAM Replacement: adım 2, 3 resimden 2. HP Compaq 6910p RAM Replacement: adım 2, 3 resimden 3.
      • Locate the release latches marked in red.
      • Press down on the release latches simultaneously to release the RAM.
      • Remove the RAM.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tyler Fricks
531 İtibar
5 adet Kılavuz yazıldı
Ekip
Montana Tech, Team 3-2, Shirk Fall 2015 Montana Tech, Team 3-2, Shirk Fall 2015 üyesi
MTUM-SHIRK-F15S3G2
5 Üyeler
46 adet Kılavuz yazıldı
5Kılavuz Yorumları
Can The RAM in this machine run with anything more then just 2GB's? I am just wondering.
Marshall WahlstromHelgren - Yanıt Paylaş
This laptop can run even 8gb ram (2x4gb), the second slot is under the keyboard.
Zar' Roc - Yanıt Paylaş
How many gb of ram should be put in the back….a 4gb  or can an 8gb ram be inserted in the back so you can not have to put any more under the keyboard if you wanted to just upgrade to 8 gb at one time or 4gb at one time and not ever have to buy 2gb, 4gb or 8gb.  answer me at natefoster@bellsouth.net.  I have in my HP6910p  a 2gb ram and a small 60 harddrive and the computer seems to be slow.  Do I need to increase the ram or the harddrive  or both.  Help me with this.  I am waiting too long to start the computer up.  It is a good computer. What should I do to get more speed.
natefoster - Yanıt Paylaş
where´s the second slot located?
Patrick Wirth - Yanıt Paylaş
It is under the keyboard. There a few youtube videos showing how to remove the keyboard and get to the second slot.
Dynasty - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 44
Her zaman: 4,363
