Ana içeriğe geç
HP Compaq C700 Battery Replacement
  1. HP Compaq C700 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Battery Replacement: adım 2, 1 resimden 1.
    • On the underside of the laptop, locate the sliding lock that keeps the battery in place.
    • Using your finger, slide the battery lock to the left to unlock the battery. Once the battery is unlocked, it is free to be removed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Taylor Johansen
690 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-6, Martin Fall 2016 UMass Dartmouth, Team 5-6, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G6
3 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
thanks - appreciate this advice as I wasn’t able to get the battery out and thought I was missing something, but then I just tried harder!
Albert Einstein - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 1,371
