Ana içeriğe geç
HP Compaq C700 Keyboard Replacement
Neye ihtiyacın var
  1. HP Compaq C700 Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Keyboard Replacement: adım 2, 3 resimden 1. HP Compaq C700 Keyboard Replacement: adım 2, 3 resimden 2. HP Compaq C700 Keyboard Replacement: adım 2, 3 resimden 3.
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
    There is a 3rd screw under ram door
    Noah Galegor - Yanıt
  3. HP Compaq C700 Keyboard Replacement: adım 3, 1 resimden 1.
    • Gently lift up and remove the keyboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Taylor Johansen
690 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-6, Martin Fall 2016 UMass Dartmouth, Team 5-6, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G6
3 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
er zijn 3 schroeven aan het keyboard
marcel - Yanıt
there is a third screw holding in the keyboard located under the RAM cover not mentioned in this guide, please make sure you remove that too or else you may end up warping your keyboard like my friend did with his C700.
Blackblur610 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 825
