Ana içeriğe geç
HP Compaq C700 Touchpad Replacement
Neye ihtiyacın var
  1. HP Compaq C700 Touchpad Replacement, Keyboard: adım 1, 1 resimden 1.
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
    FixBot'a Sor
    Yorum Ekle
  2. HP Compaq C700 Touchpad Replacement: adım 2, 3 resimden 1. HP Compaq C700 Touchpad Replacement: adım 2, 3 resimden 2. HP Compaq C700 Touchpad Replacement: adım 2, 3 resimden 3.
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
    FixBot'a Sor
    Yorum Ekle
  3. HP Compaq C700 Touchpad Replacement: adım 3, 1 resimden 1.
    • Gently lift up and remove the keyboard.
    FixBot'a Sor
    Yorum Ekle
  4. HP Compaq C700 Touchpad Replacement, Touchpad: adım 4, 1 resimden 1.
    • Locate the twenty 3 mm Phillips head screws.
    • Unscrew them using the PH0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. HP Compaq C700 Touchpad Replacement: adım 5, 1 resimden 1.
    • Remove the hard drive by pulling on the plastic tab and lifting upward.
    FixBot'a Sor
    Yorum Ekle
  6. HP Compaq C700 Touchpad Replacement: adım 6, 1 resimden 1.
    • Locate and unscrew the two Phillips head 3 mm screws on the wireless card.
    FixBot'a Sor
    Yorum Ekle
  7. HP Compaq C700 Touchpad Replacement: adım 7, 1 resimden 1.
    • Unhook the two wires connecting to the wireless card by gently pulling them out.
    FixBot'a Sor
    Yorum Ekle
  8. HP Compaq C700 Touchpad Replacement: adım 8, 1 resimden 1.
    • Gently lift and pull out the card.
    FixBot'a Sor
    Yorum Ekle
  9. HP Compaq C700 Touchpad Replacement: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Locate the power button connector wire.
    • Using the tweezers, unhook the wire.
    FixBot'a Sor
    Yorum Ekle
  10. HP Compaq C700 Touchpad Replacement: adım 10, 2 resimden 1. HP Compaq C700 Touchpad Replacement: adım 10, 2 resimden 2.
    • Press and hold the lock to pop the panel piece above the keyboard and pull up to remove it.
    FixBot'a Sor
    Yorum Ekle
  11. HP Compaq C700 Touchpad Replacement: adım 11, 3 resimden 1. HP Compaq C700 Touchpad Replacement: adım 11, 3 resimden 2. HP Compaq C700 Touchpad Replacement: adım 11, 3 resimden 3.
    • Unplug the remaining wires using the tweezers.
    FixBot'a Sor
    Yorum Ekle
  12. HP Compaq C700 Touchpad Replacement: adım 12, 1 resimden 1.
    • Gently pull out the three wires.
    FixBot'a Sor
    Yorum Ekle
  13. HP Compaq C700 Touchpad Replacement: adım 13, 2 resimden 1. HP Compaq C700 Touchpad Replacement: adım 13, 2 resimden 2.
    • Locate the four 3 mm Phillips head screws.
    FixBot'a Sor
    Yorum Ekle
  14. HP Compaq C700 Touchpad Replacement: adım 14, 1 resimden 1.
    • Unhook the display connector wire.
    FixBot'a Sor
    Yorum Ekle
  15. HP Compaq C700 Touchpad Replacement: adım 15, 1 resimden 1.
    • Gently disconnect the display by pulling it upwards.
    FixBot'a Sor
    Yorum Ekle
  16. HP Compaq C700 Touchpad Replacement: adım 16, 1 resimden 1.
    • Locate the disk drive on the side of the device.
    • Remove it by pulling it all the way out.
    FixBot'a Sor
    Yorum Ekle
  17. HP Compaq C700 Touchpad Replacement: adım 17, 1 resimden 1.
    • Use the PH0 screwdriver to remove the two 3 mm Phillips head screws in the disk drive port.
    FixBot'a Sor
    Yorum Ekle
  18. HP Compaq C700 Touchpad Replacement: adım 18, 1 resimden 1.
    • Disconnect the touchpad connection using the tweezers.
    FixBot'a Sor
    Yorum Ekle
  19. HP Compaq C700 Touchpad Replacement: adım 19, 1 resimden 1.
    • Use the plastic opening tool to pry up all sides of the device cover.
    FixBot'a Sor
    Yorum Ekle
  20. HP Compaq C700 Touchpad Replacement: adım 20, 1 resimden 1.
    • Remove the cover by lifting it.
    FixBot'a Sor
    Yorum Ekle
  21. HP Compaq C700 Touchpad Replacement: adım 21, 1 resimden 1.
    • Use the PH0 screwdriver to remove the six 1 mm Phillips head screws surrounding the touchpad
    FixBot'a Sor
    Yorum Ekle
  22. HP Compaq C700 Touchpad Replacement: adım 22, 1 resimden 1.
    • Use the tweezers to remove the touchpad wire connection.
    FixBot'a Sor
    Yorum Ekle
  23. HP Compaq C700 Touchpad Replacement: adım 23, 2 resimden 1. HP Compaq C700 Touchpad Replacement: adım 23, 2 resimden 2.
    • Use the plastic opening tool to pry up the touchpad cover.
    • Lift and remove the touchpad cover.
    FixBot'a Sor
    Yorum Ekle
  24. HP Compaq C700 Touchpad Replacement: adım 24, 1 resimden 1.
    • Use the blow dryer to melt the adhesive around the edge of the touchpad.
    • The touchpad is now free to be removed.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Taylor Johansen
711 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-6, Martin Fall 2016 UMass Dartmouth, Team 5-6, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G6
3 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
I need Compaq laptop c700 Touch pad
So how can I get it?
Suraj Verma - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 41
Her zaman: 1,722
