Ana içeriğe geç
Giriş
If heating problems occur with the laptop, it may be essential that the fan be removed to be cleaned or replaced. This can be done easily after disassembling the laptop.
Aletler
Hiçbir alet belirtilmedi.
  1. Locate cooling fan directly to the left of copper heat sink.
    • Locate cooling fan directly to the left of copper heat sink.
  2. Locate the black/grey/brown colored cord and carefully disconnect it from the motherboard. Place cord off to the side so that it is out of the way.
    • Locate the black/grey/brown colored cord and carefully disconnect it from the motherboard.
    • Place cord off to the side so that it is out of the way.
  3. Android Tamir Setleri
    Yeni bir ekran veya pil, bir tamir kiti kadar yakınında.
    Hemen Alışveriş Yapın
  4. Locate and remove the two 7.0mm Phillips #1 screws on the top left and top right corners of the cooling fan. Locate and remove the two 7.0mm Phillips #1 screws on the top left and top right corners of the cooling fan.
    • Locate and remove the two 7.0mm Phillips #1 screws on the top left and top right corners of the cooling fan.
  5. Remove the fan from its spot. Remove the fan from its spot.
    • Remove the fan from its spot.
Sonuç
Mateo Cuellar
592 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 17-4, Forte Spring 2015 Cal Poly, Team 17-4, Forte Spring 2015 üyesi
CPSU-FORTE-S15S17G4
3 Üyeler
6 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
Her zaman: 450
