Ana içeriğe geç
HP Compaq NC6120 Monitor Replacement
Neye ihtiyacın var
  1. HP Compaq NC6120 Monitor Replacement, Monitor: adım 1, 2 resimden 1. HP Compaq NC6120 Monitor Replacement, Monitor: adım 1, 2 resimden 2.
    • Locate and remove four black 5.1mm Phillips #1 screws from the left and right sides of the monitor.
    FixBot'a Sor
    Yorum Ekle
  2. HP Compaq NC6120 Monitor Replacement: adım 2, 3 resimden 1. HP Compaq NC6120 Monitor Replacement: adım 2, 3 resimden 2. HP Compaq NC6120 Monitor Replacement: adım 2, 3 resimden 3.
    • Using a small spudger, remove the four black plastic covers from above the monitor, revealing screws underneath.
    FixBot'a Sor
    Yorum Ekle
  3. HP Compaq NC6120 Monitor Replacement: adım 3, 1 resimden 1.
    • Remove the four screws that were just uncovered. They are 6.2mm 3.0 flathead screws.
    FixBot'a Sor
    Yorum Ekle
  4. HP Compaq NC6120 Monitor Replacement: adım 4, 1 resimden 1.
    • Pry off the plastic case surrounding the monitor.
    • A spudger may be needed to pry off the case.
    FixBot'a Sor
    Yorum Ekle
  5. HP Compaq NC6120 Monitor Replacement: adım 5, 3 resimden 1. HP Compaq NC6120 Monitor Replacement: adım 5, 3 resimden 2. HP Compaq NC6120 Monitor Replacement: adım 5, 3 resimden 3.
    • Remove the black and silver cable, located directly below the monitor.
    • Proceed to pull monitor approximately 10cm away from the back of the laptop case.
    FixBot'a Sor
    Yorum Ekle
  6. HP Compaq NC6120 Monitor Replacement: adım 6, 2 resimden 1. HP Compaq NC6120 Monitor Replacement: adım 6, 2 resimden 2.
    • Remove the grey cable (with yellow tip) connecting the monitor to the back plastic casing and the monitor will be free from the rest of the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mateo Cuellar
601 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-4, Forte Spring 2015 Cal Poly, Team 17-4, Forte Spring 2015 üyesi
CPSU-FORTE-S15S17G4
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 1,792
