Ana içeriğe geç
HP Compaq Presario CQ56-110US CD Drive Replacement
Neye ihtiyacın var
  1. HP Compaq Presario CQ56-110US CD Drive Replacement, CD Drive: adım 1, 2 resimden 1. HP Compaq Presario CQ56-110US CD Drive Replacement, CD Drive: adım 1, 2 resimden 2.
    • Loosen the two indicated screws on the panel using a Phillips screwdriver with a PH1 head size.
    • The screws do not come free from the panel. They only need to be loosened enough so that the panel can be lifted/pried using a plastic opening tool.
  2. HP Compaq Presario CQ56-110US CD Drive Replacement: adım 2, 1 resimden 1.
    • Use the screwdriver to unscrew the four 5mm screws holding down the hard drive.
  3. HP Compaq Presario CQ56-110US CD Drive Replacement: adım 3, 2 resimden 1. HP Compaq Presario CQ56-110US CD Drive Replacement: adım 3, 2 resimden 2.
    • Use plastic opening tools to lift up the hard drive. Set aside the hard drive without disconnecting the wire.
  4. HP Compaq Presario CQ56-110US CD Drive Replacement: adım 4, 1 resimden 1.
    • Use a Phillips screwdriver with a PH0 head type to unscrew the indicated 5.5mm screw.
  5. HP Compaq Presario CQ56-110US CD Drive Replacement: adım 5, 1 resimden 1.
    • Use plastic opening tools to pry open the CD Drive.
  6. HP Compaq Presario CQ56-110US CD Drive Replacement: adım 6, 1 resimden 1.
    • Use your hands to pull the CD drive out and remove it from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Iyonna L. Tynes
446 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-4, Eyestone Spring 2017 USF Tampa, Team 8-4, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S8G4
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 24
Her zaman: 881
